Marc
If your current engine specs are "standard" CSL then set it at the factory limit for the engine to start with.
However.......
The physical rev limit is usually determined by the valve springs, you have to avoid "valve bounce" ie the valve doesn't have time to close completely before the lobe of the cam comes around again
If your going for a "fast road" or race cam profile you need to uprate your valve springs. W&N in Germany would be a good place to start
Your quoted power ouput is pretty impressive right now, even if its at 5400. Why do you want to move it up the rev range :?:
Anyway......
Where you get peak power in regard to the rev range is determined by many factors including, but not limited to:
1...Cam profile
2...Valve size and style (4 valves per cylinder versus 2)
3...Stroke of the engine generally long stroke - max power/torque at lower revs compared to a short stroke or "oversquare" engine.
4...Inlet tract lengths - generally short means peak power/ torque at higher revs, longer ones lower down, with more torque.
5...Throttle body size - physical amount of air that can get into the engine
6... Porting of the engine - air flow path
Basically with the design of this engine it will be very difficult to move the power way up the rev range, you can increase the power but moving the power would mean having to bolt on a BMW racing cylinder head as per the racing E9s
Open your wallet and say after me - help yourself!
I have built rally car engines, fiat 1500cc with Abarth cams and valve springs, added an extra 1500 rpm to about 8000rpm before valve bounce occured.
That stated peak power was at about 6000 after I had finished with it
However that engine was dynamically balanced, including the clutch assembly, ported, different injectors, cold air ducting, electric rather than mechanical water pump.... the list goes on!
For stage rallying it was handy to "hang" on to a lower gear sometimes, but it was a bit of a pig at low speeds....
I would be very interested in your Emerald ECU setup, could you let me know how you did it?
Cheers
Malc
