Trailing Arm Reinforcement
nobrakese28
Hello,
Has anyone reinforced their trailing arms?
What about the sway bar link tabs on the arms?
Is there a kit available?
Is anyone running the Ireland Engineering toe/camber correction kits?
If you wouldn't mind sharing photos of your set up that would be great.
I have 3.0CS trailing arms out of parts car. Aside from one of the trailing arms having a few dents, they look okay and measure out symmetrical to each other.
The genius of a previous owner actually welded the trailing arm bolts to the mounting clevis......That was fun to remove.
Thanks,
Marco
Camber- toe plates
Hope this helps: Guys at IE said no need to reinforce unless racing, it looks thick enough back there for me. Don't worry about the gap in pic 5, just weld it good, and I took everything back apart- just seemed easier. Probably took an extra hour but I wanted to measure the stuff just right.
