trim hardware questions
Bearmw
Western, MA
I am trying to find sources for the hardware to secure two of the trim pieces for my 72 Bav. I have done some searching but I am unsure what ways I can best secure the C pillar cover and the rear upper chrome strip located at the C pillar. I am willing to use whatever works, whether original BMW or otherwise.
Here are the pieces I am referring to:
The chrome strip is held on by studs and nuts which are hidden under the headliner. The black plastic plugs/nuts can be found from BMW, many different sizes were used to attach badges and emblems.
Grommet 51 14 1 807 495
Bearmw
Western, MA
Upon further inspection I realize I have some of the 51141807495 grommets from Wallothnesch but they look different from what looks like the originals. The Wallothnesch ones are a bit too large O.D. and the head prtion is thicker too. I might be able to get them to work with shaving them down slightly and/or using a heat gun to get them to fit but I would have preferred not to. Has anyone had an issue with these?
bavbob
Boston, Ma
You can try to reach the chrome strip from the trunk if your arm is long enough. I got away with it. I use 3m strip calk for everything so i put a little ring around each attachment site/grommet for a water seal.
I think he means the chrome strip at base of C pillar not the belt trim. It mounts inside the headliner.
bavbob
Boston, Ma
More than one way to skin a cat, I did change mine from access via the trunk, along side the wheel well.
