My in-dash turn signal indicator is always on. When the turn signal itself is engaged it blinks a bit, from bright to brighter, though it never is dark. As I recall, if correct it should be dark unless engaged, at which point it should blink on/off/etc.
So, I removed the turn signal relay and opened it up. It's pristine inside, with no corrosion, loose wires, etc. The connectors are clean and shiny but I steel-wooled them anyway.
By fiddling with the relay when connected I can get it to work properly, but it has to be in EXACTLY the right position (that is, the connectors into the relay needs to be at a precise angle/disposition/etc. in relation to the relay itself), which with even smooth driving it would not maintain. So, even arranging it "just so" and securing the connections in that position is unlikely to work for long and is not long-term solution.
Ideas? Thanks in advance.
