That’s a relatively common problem. If you use the search function (I used the work flocking) you’ll come across some advise on fixing it your self.
Here’s an example....
Not had the time to really get stuck into the car last week, but I have managed to do a few things. The glove box was delaminating , its now back as it should be and ready for a clean and re flock. The fuel tank is now out of the car and although it looks a bit scabby it still held ¼ tank of...
The other question that arises is that the separation can be extreme enough that you can crack the styrofoam or vinyl, bringing them back together. I placed the thing in the over at about 120F in hopes of reuniting the seperated parts and it was a no go. I tried to do this in steps to slowly bring them together and still no go. Any other ideas?
The "Rubber Gasket Rejuvenation" thread has a suggestion to make old gaskets pliable again, to soak the part in a mix of oil of wintergreen and alcohol. Might try that on your vinyl prior to glueing it back onto the steel.
send it off to just dashes
ive only had excellent result from them and they did a my whloe dash and spr\eedo cover and bottom and side panels
in quick order
others havent faired as well
i called a head of time and it was excellent service
i have one more part to do w/ no trepidations
For best result - rust need to be removed mechanically or chemically (your choice).
1. Cleaning
2. Degreasing
3. Rust converter
4. Good automotive water resistant elastic adhesive.
5. Fix with clamps
