Upper Right Door Armrest Piece Needed
CaptainJack767
Amherst, NH
Took a friend for a spin today.
He decided the door needed to be closed forcefully and broke the top piece.
Might anyone have a black one from a parts car?
My search kept coming up NLA.
TIA!
Jack
603-801-7610
Took a friend for a spin today. He decided the door needed to be closed forcefully and broke the top piece.
Yes, people who aren't familiar with older cars - particularly e3's and e9's - do tend to do that.
They are available new as p/n 51411815235. See: https://www.bmwmobiletradition-online.com/bmw/showparts.do?model=3435&mospid=47811&btnr=51_3457&hg=51&fg=50 though at $59/each (plus tax, shipping, tariffs, ...) a used one is going to seem appealing. But if you install a used, plastic, 35 year-old part, it is going to be just as brittle as your old one.
Whether you use a new or a used piece, you should add a pair of these: https://e9coupe.com/forum/threads/upper-right-door-armrest-piece-needed.51385/ which serve to reinforce the plastic. It's nice that Coupe King makes these, but at $55 (plus tax, shipping, ...) they are a bit pricey. Back before these things existed, I also thought up the idea and fabricated a pair out of bar stock from my local hardware store.
Ah, yes, my wife did the same thing. Look at coupeking.com for the metal piece that you can install in there once you find the black part to prevent this problem in the future. I would also move this thread to the Parts Wanted forum since it might get more attention there. Finally, I think that W&N occasionally has this part, not sure if you had checked there yet.
(looks like we were answering at the same time!)
I believe that someone is reproducing that part. If you find a 35 year-old used part, it is going to be just as brittle as your old one.
But whether you use a new or a used piece, you should add a pair of these: https://e9coupe.com/forum/threads/upper-right-door-armrest-piece-needed.51385/ which serve to reinforce the plastic. It's nice that Coupe King makes these, but at $55 (plus tax, shipping, ...) they are a bit pricey. Back before these things existed, I also thought up the idea and fabricated a pair out of bar stock from my local hardware store.
Thank you.
Yes, I’ve already ordered the top pieces.
How do I move it?
Or, just start over?
Thx
Ha, I misunderstood your question, I thought you were asking about how to remove the part. Well, see below for that info.
It's usually the black piece below that chrome that snaps. The chrome is released from below, there are two screws holding it down. Once you lift off the chrome there are two larger screws, one aiming downwards holding the black part to the armrest and then a large one holding the black part to the door. THat black plastic is the bridge between those two, the metal L sits in that same junction and establishes a metal rather than plastic bridge there so that the plastic isn't bearing the load.
For future reference, those parts take dye well. I dyed mine to match the color of my seats. This means when seeking a replacement, you can buy any color you can readily find and simply dye it to match the car. Obviously, this is easiest with black.
Agree on the dye. Mine were black and I spray-painted SEM red. Here are two shots of taking apart since I was doing this this afternoon. And I was wrong, one screw from the underside. You can see the metal L-bracket in place here and how it would prevent the failure of the plastic.
If you can’t pop off the chrome (mine wedged in there) use a straight pick and push up through the bottom screw hole.
Just will add in that it’s always amazing how the interior photographs. This looks like Corvette interior cherry red but is actually much oxblood. We know this anyways nowadays, but can’t always trust what you see in pictures.
Early coupes and early e3 did not have that small screw, it just snapped in.
Interesting, I wonder if mine had been updated at some point then. I have a 72' euro so one of the earlier CSi. Was there a difference in Euro vs US?
And man, what a detail to know! You are the walking (driving) encyclopedia of the E9/E3
