I had to change the water pump on my '73 3.0CS. It appears the viscous clutch is not working correctly. When I tighten the center bolt of the fan, the fan will not spin. I.e, i believe the clutch is frozen.
I'm a Volvo guy with one BMW. On the Volvo, the viscous clutch is in part of the finned hub that the fan bolts to with 4 small bolts. From reading the BMW service manual it appears that the BMW clutch mechanism is behind that, and that is the unit that needs replacing. Is that the case?
I see what I think I need listed for the 1974 and 75 models, but not the 1973. Where might I find one for the 73?
The picture below is what I believe is NOT the viscous clutch. Am I correct?
