raulvargasdelos
Looking for the part, it would sit on top of two Webber 26/32.
Try to find the adapters with the stud to hold the air cleaner centered over the carb. The more typical ones shift the air cleaner assembly about 1/2" rearward which requires redrilling the hold down holes in the air cleaner and makes it difficult to fit the hot air hose from the exhaust manifold shroud, the cold air intake hose to the front panel, and the hose from the valve cover to the air cleaner....and you'll need adapter plates for Webers as well, right? As is it will fit only the Zeniths.
Thanks, can you upload a couple of pictures?, do you have the adapter as well?I've got one $200 plus shipping. Color isn't quite right and some chips around the edges but all around good shape. You'll probably want to rattle can it or powder coat. Updated price.
I'll upload some pictures today, I don't know if it has the adapter but I'll open it up and take pictures, top and bottom. Maybe someone on the forum can tell us.Thanks, can you upload a couple of pictures?, do you have the adapter as well?
