Motorhead
A friend is restoring an E3 2500 and upgrading to 3.0Si/CSL brakes. But the rear brakes need a spacer and fitting this means that you lose too much of the wheel bolt thread to be safe and the hub is not then deep enough to locate in the wheel hub, so it won't centrally locate.
It turns out that the 3.0Si/CSL rear hub is deeper than the 2500 hub.
Does anybody have or know where you can get a pair of 3.0Si/CSL rear hubs - only need the outer part?
You can read about the restoration at link below if you're interested...
http://www.bmwcarclubforum.co.uk/forum/forum_posts.asp?TID=5002&PN=5&title=e3-owners-where-are-you
Located in UK
Located in UK
