Wanted top radiator bracket
James Poulter
Royal Leamington Spa
Hi,
I seem to be missing my top rad bracket can anyone help part number 17111102011 item 5 in the picture.
Which radiator? I'm pretty sure I have one for an automatic radiator.
Let me double check to see what I have. I had thought there were two brackets; a longer one like the one shown in the picture you posted and a shorter one to accommodate the transmission cooling bulge on the radiator's right side. Because my car was originally an automatic, I am pretty sure I have a shorter bracket that I removed when I did the 5 speed swap. In any event, yes, if I have what you need it would be in my stash of extra parts and I would gladly sell.
Yes, I have the one pictured in your original post. $20 plus shipping. Send me your address in a conversation.
Probably won't have the welded one, but will check. As to the other side, there are two different parts. The automatic version is much shorter because the automatic radiator has a section on the end to cool the transmission fluid. So when I said which one, I meant manual or automatic.
Alprada - I have a second longer bracket, and I also have a shorter bracked that can be used for the other side. Same pricing as the other - $20 each.
My address:
Alvaro Prada - Sussy d’ Leon
11200 Pines Blvd, suite 200
Pembroke Pines FL 33026
USA
