decoupe
(deceased)
The symptoms are rapidly rising temp gauge, steam coming out of engine bay, lots of coolant underneath. Seems pretty obvious but it only has 40,000 mi on it since 2000. Since there isn't a cap on the radiator how do you check to see if it is pumping? The expansion tank is the high point in the system so looking in there shows nothing.
All the hoses and clamps are good, viscous clutch upgrade and multi blade fan (9?) turning when the engine runs. It looks like the coolant came from the small expansion tank relief hose. No bearing noise, oil is clear and no warning signs of any type. All of this in rush hour downtown traffic. Could have been worse. Flat deck trip to the hanger and I'll pick it up with the trailer next week.
Searched "water pumps" (57 hits) and there doesn't seem to be a recommendation on brands - just buy from reputable seller. Before I order one could this be anything else? Faulty (stuck ) thermostat? Air bubble? Alien adduction?
Sad part is a renovation on the house and hand surgery Oct 8 means that's it for this years driving.
Doug
Doug
