Tom H
New Member
Hi all. I'm a relitivley new member. I bought my '73 Bavaria about a year ago and have been slowly making improvments with lots of help from the archives here. The car came with a newly installed new (Spanish) set of Weber 38/38 with the Redline linkage setup. The problem I'm having is that coming off if idle is very difficult to do smoothly. The pedal is very stiff when the car is idling and to get past the stiff point half the time I overshoot and it ends up at maybe 20% into the throttle. It makes for a pretty jerky experiance. When the engine is off, the hard spot is not there. I wonder if I'm pushing against the vacuum pulling the throttle blades closed, that's what it feels like. Last summer as was able to adjust the position of the drop arm off the firewall and the idle postition of the bell crank, so that the bell crank was sitting all the way back on it's stop arm when the car was at idle, and this improved things, but not completely.
I've been told that the Redline linkage is not the best, and that changing the linkage may correct the problem, but all the options that I've heard about seem to be NLA.
If anyone has any ideas or insights, it would be greatly appreciated.
Thanks.
additional details:
-3.0 engine, assumed stock, s/n on block indicates '75 e12
-5sp OD Gettreg trans, possibly also from '75 e12
Thanks.
additional details:
