Weber carb linkage over-rotates and locks full throttle
I apologize for how grubby/corroded everything looks! My coupe has basically been on the road since it was sold in 1970. Re-painted, re-upholstered, maintained but certainly never fully restored.
I can relate. I've gone through most of my E3 and everything is either newly painted, new parts or cleaned up. I opened the hood on my coupe the other day and just shook my head. Let's just say I don't open the hood when I go to Cars and Coffee. :)
Clever solution. I considered putting a bracket/stop mounted off of the motor mount since there's a few bolts in the right spot but in the end I wanted to know that the linkage couldn't physically over rotate and lock, just in case for some reason the stop didn't work. My test plate link proves that it's a simple fix, in my case it's a 50mm ball/socket rod to do the trick.
This is what I was referring to in my post above. In this picture you can see the stop. It is the angled piece toward the right of the picture. When bolted in place, there is no way this could fail. The question is whether it stops the Z shaped portion of the bell crank in the right position to address this particular problem, and since I have a different linkage and different carbs, I can't tell.
I'm thankful you're doing the thinking that the engineers of the kit should have done. Have you tested the linkage via the pedal yet? I'm curious whether the effort / feel is different with shorter or longer levers involved.
I went first, you have nothing to worry about!
I found a photo of a '73 CS parts motor that had the linkage stop. Looks like it stops it in the return position and wouldn't help in the WOT position. At least not without some mods. How is it suppose to work with the adjustment of the idle stop screw?
My zeniths arenin a box and my DGAS38’s don’t seem to have this problem.
But zero knowledge has never stopped me from opening my mouth, so here goes:
Is it possible there is a different arm on the front and rear carba and youv’e got a rear carb arm on the front?
Otherwise I like the idea of getting slightly longer adjustable push rods for the two carbs.
John
John
The carb links are the same length. One is set in more of a non-adjustable way and the second has an adjustment to fine tune it to match the first one.
A followup on the linkage. I looked around quite a bit for adjustable linkage for the carbs and couldn't find anything in the right size. All were too long, so I started searching for just the ball end connectors and bought some nylon ones that looked okay. I got them in over the weekend and they're much better quality than I expected and after cutting up a couple bolts for the links I got them on the carbs. They look like they'll work fine. We'll see. Pre-made link assemblies were $22-25/ea plus shipping, if I could find them. These links cost me $9 for both including shipping. I'm a proud cheap bastard!
Again...thanks Forum for providing valuable experiences and information!
I am reassembling my bavaria and converting over to 32/36s and have found this same problem. In addition to possible WOT, the gas pedal has a 2 stage feel; normal feeling for the first bit and then a heavier feel as the linkage flips over and is over centre. Adjusting the linkage to be longer keeps it from going WOT but the 2 stage feel is still their.
I like the solution of the linkage pulling the carb linkage (with carb linkages that are clocked at about a 4 o'clock position) compared to the linkage pushing up on the carb linkage (carb linkage clocked at about 2 o'clock position). I may have some spare carbs with the linkage or maybe its worth fab'n a few up either out of weber linkages or some steel plate.
I think a solution may also be orienting the adjustable linkage so it is more vertical vs. sloping (as seen below). This solution is theoretical and requires moving the ball pivot closer to the linkage's rod by drilling a hole and using a bolt on pivot ball. I included a picture below with a theoretical blue circle of the new position of the pivot ball.
I am going to look into both solutions and will report back...
Regards,
Bill
You'll have to mock something up to test the amount of travel. The arm on the carb has to go vertical to be WOT so putting the ball joint where your blue mark is doesn't seem like it would have enough travel. Because the two arcs travel away from each other it makes it more difficult for a smooth transition.
Back in my mechanical design days I'd just make some 3D models and test it a bunch of different ways.
HI
Asking Google, I have found the throttle linkage for Weber ICH or ICT carbs. This has the correct orientation to put it under the throttle rod levers. I ordered a few and will see when they arrive. In the mean time I will play with mockups and fab up a few options.
Regards,
Bill
Hi,
So far I tried,
1. original throttle rod + longer horizontal throttle arms = this was really prone to wide open throttle and the gas pedal had a 2 stage feel (easy then much harder to push which resulted in WOT),
2. original throttle rod + shorter downward carb throttle arms = this did not work at all; there was no room for linkage arms to pull up on the carb's throttle arms. I was hoping this would work because I think WOT would not happen. I bent in some offset like the longer horizontal arms.
3. Weber throttle rod and adjustable throttle arms + longer horizontal carb throttle arms = this works quite well; the pedal has a consistent feel to it; but if pushed too far WOT happens. WOT happens because of flex/slack in the components not because of setup. I plan to make a 'stopper plate' for this set up. See pics.
The combo I did not try (but may) is,
4. Weber's linkage rod and adjustable arms kit + shorter downward carb throttle arms. The longer Weber adjustable throttle arms may allow the shorter downward carb throttle arms to be pulled up without WOT happening.
By "shorter downward carb throttle arms" are you referring to the arms mentioned in your post #30? The part # 4502720200 from Classic Carbs in the UK?
Have you done any experiments using the original, BMW bellcrank that acts on both carbs? The long arm with three, welded-on levers that gets pulled down by the bellcrank on the side of the block and pushes up on the two carbs? Your pictures all show an aftermarket part in that location.
Hi
I have not received those yet. Though I found the mentioned shorter downward clocked ones in my tickle trunk.
Yes; 1 and 2 above used the original throttle rods (you call this the bell crank). I have not tried to re-position the long rods that come up from the mechanism on the block. I am assuming these do not need modification.
Bill
Old thread but I'm looking for these connectors now. I used the part# on the bag (14581495) but didn't get a hit. Do you know the diameter of the ball of the linkage? LiftSupportsDepot. com only shows having 6/8/10mm connectors. Thank you-
Check out Boats.net these I found to be an exact copy of the original plastic end and comes with a ball end It is all 5 mm if I remember right
Thanks, Rick
MERCURY OEM BALL JOINT ASSEMBLY BALL ASSEMBLY | F269141-1​
Part #:F269141-1
⚲Hover to zoom
Add to list
$17.88SAVE 16%
$21.25
  • Guaranteed product fitment
  • Exact OEM part in new condition
  • Easy, No Hassle Returns
  • Authorized Dealer
See Full Details
In Stock
Add to Cart
I am working on a complete replacement for the original dual downdraft Zenith/aftermarket linkages. None of the options available (Zenith, JAM, . . . ) were specifically engineered to work on the E9/E3s with Weber downdraft carbs. This one will be and it will feature all stainless steel components with Heim joints and commercial grade balls/sockets to last. I hope to have these in production this summer and I let everyone know when that happens.
We already have a link on the 2002sonly website in anticipation of this.
I am working on a complete replacement for the original dual downdraft Zenith/aftermarket linkages. None of the options available (Zenith, JAM, . . . ) were specifically engineered to work on the E9/E3s with Weber downdraft carbs. This one will be ......
Interesting. My e9 has 32/36's and suffers from the "over-centering problem". I "solved" it by creating a stop that prevents it from going full throttle and locking up, but admittedly, that's a crude fix. So this definitely interests me. Two questions:
- When you say this new product is "specifically engineered to work on the E9/E3s with Weber downdraft carbs", does that mean that your have re-engineered the linkage geometry?
- I don't see an existing e9 linkage kit on your site for for Zenith carbs; will this new kit accommodate Zeniths as well as Webers?
Interesting to find this thread. My CS has this same exact issue with its Weber down drafts. First time it did that, it scared the crap out of me!! Fortunately I can un-stick it by putting my toe under the gas pedal and pulling up, but wow, something's definitely not right there...
That said, this should be a fairly simple problem to solve. I did a small model of this. The system is VERY sensitive to the length of the actuator arm (the one that moves the linkage between the carb lever and the crank lever. If that arm is too short, then the link goes over center just before WOT and the spring onthe carb then worked in the opposite direction against the crank lever. Note that if the carb actually makes it to WOT before the lever goes over center, then this issue will not occur because the carb will stop the motion of the lever.. So the throttle is actually locking up just shy of WOT.
The other observation folks have had is the "two stage" feel to the pedal. This is because the force angles are changing a lot in this setup. at the start the linkage is oriented at a reasonable angle to the lever, so the lever causes it to move a lot for any given rotational change. Near WOT though, the lever and the linkage are almost co-linear, so the lever has almost no effect on the motion of the link.
I think fixing the "feel" will require repositioning the pivots for the linkage so the force angles are more uniform over the full travel.
I did some additional research. This system is called a 4-bar linkage. It can be configured in a variety of forms.
Here is a simulator:
https://dynref.engr.illinois.edu/aml.html Scroll down to the "full linkage model".
When you watch the animation, you can see that C (which is the output link position) doesn't change in exact sync with D (the input link position). This is what cases the change in pedal feel as the input link position is moved.
If you mess with things like the input angle limit (see the attached pic) you can set it up so it "sticks", sorta. what happens is that the link gets over center, and so the output node stops near the peak, reverses and then stops and goes all the way back. In the real system the carb spring causes the mechanism to hang at that inflection point. While I would be reluctant to remove the carb shaft spring, doing sow would probably allow a return bring on the input linkage to bring the mechanism back to the start
