viphoto
Here is a weird one...can't say I have seen this before. Parked the car a month ago for pending brake booster rebuild...and a couple weeks later noticed a big puddle under diff. it has continued to leak since. Assumed I screwed up putting one of the seals in (only changed side seals and big oring..front wasn't leaking and I didn't want to mess with the crush sleeve.) So I finally decided to see which seal gave way and low and behold both were ok as was both drain plugs.. Wiped it down and watched it over a couple of days... seems there is a small weep hole in the side fairly low so it keeps dripping. Anybody seen this before? Diff was pretty greasy when I pulled it to do seals and paint. Maybe defect in cast iron..seems like a weird place for it to crack..I think maybe paint held it for a while ... I am sure welding is the best solution (and biggest challenge/hassle) May give the less approved "JB weld" or Epoxy solution a try..(I had good luck with hi temp JB weld on the block of an old MG race car a number of years ago).... any other options / solutions welcomed.
