What color should the 3 strut top acorn nuts be?
jjs2800cs
I zinc plated my strut dome nuts and then used yellow chromate to give cadmium look and it kind of seals the zinc coating as the raw zinc tends to disappear in time as was noted.
Yes not original but they look nice at least to my eyes, as most of the other visible engine and suspension hardware got the same treatment
Jjs2800cs
Gransin
Vasa, Finland
Anyone seen these plastic caps on top of hex m8 nuts on an e3 before?
I tried all the flavors- from blue/clear zinc to nickel to yellow zinc to chrome.
I liked the chrome best.
i like @Stevehose idea of satin stainless. seems like it will look the most like the original without the issue of discoloration. now if i was doing a black coupe - bling is the answer. chrome would be the second best, as long as you replace them each time you remove them ... the chrome is likely going to be damaged by wrenches / sockets with a few uses.
my guess is that people put thick washers on when they removed the USA spacers and the bolts stuck up too high - so they put thick washers on so the cap nuts would work
Yes, or like me, they cut the studs to fit the old setup.
boonies
Boonies
US - Philadelphia suburbs
I have a set of shortened studs that I think I purchased from @sfdon some time ago. I am planning to install them as part of a larger winter project. I added the stainless acorn nuts to my Belmetric order.
eriknetherlands
Netherlands, Eindhoven area
As I was busy in this part today I just took a look at my car; it's Swiss delivered, and my 6 acorn nuts on the strut towers all are chromed brass. The chrome is still shiny, however the mirror like reflection like on a bumper doesn't occur as the surface is too rough.
As my car has been restored once before I can't vouch for their correctness.
As I was thinking they were made from stainless steel or chromed brass, I tested them with a magnet.
As expected, they were non-magnetic. So I sanded the chrome layer of the back of the nut.
Turns out it is brass.
Interestingly, if you look closely at them, you can see the brass material was turned on a lathe. 3 of my 6 acorn nuts were turned soo quickly/roughly that the lines are still visible.
Also the 3 pictures from @HB Chris of the European cars, one can see that at least some of these acorn nuts clearly have the milling lines still on them, with a distinctive point in the center:
In my pictures on my wooden table are also 2 stainless domed nuts, these are clearly a bit more grey. Also 1 simple zinced nut and a zinced domed nut ( with it's cap smashed in) for color reference - these are clearly more dull. These other parts are distinctly different in color vs the 6 domed nuts on my car.
