i am not aware of the history of your car, you are a recent member with few messages, i do not know if you have this car since new or you are a recent owner,
also to say i do not know your experience and skills on automotive issues and in this particular model
in my experience carbs are one of the important parts of these cars, zeniths have a bad reputation because mechanics do not take the time and efforts to understand them and thus to maintain them well
if they have been well kept and maintained or not makes a big difference, but if you do not know the history, youd better overhaul them at once, even brand new fully restored cars hide some secrets,...
@Philippe db can tell you his story ;-)
what other owners express is certainly subjective, someone can tell you that his car runs well because he has no other reference to compare, please bear this in mind when others are giving their opinions
generally speaking you might have a problem in the choke mechanism, but is a complex thing, the only thing i can figure out are an easy check are primary butterflies
it seems extrange that you have missed a good behaviour that has been there for a while, but lets see
if you remove the air filter cover with cold engine, are the primary butterflies closed ? or open ?, if now you press the throttle linkage with your hand, what do the butterflies do ?
BTW adding gas always floods the engine so it wont start until it evaporates and recovers the right air/fuel ratio
BTW, Try not to start the procedure with "pedal to the floor", use a simple tiny push of the pedal
i will be happy to talk to you on the phone if you want, just let me know
