whats the best way to upgrade my stock 3.0cs motor
aearch
pleasant hill , ca
anyone have parts and ideas on going to a 3.3 or 3.5 i want to keep
my daul weber carbs for simplicity.
thanks
alan
x_atlas0
Clarkston, MI
To make things simpler, you could use a 3.5 short block, that way you can keep your original head/weber setup. You may have to open up the head a little more to allow for the bigger pistons, though. You will also have to rejet the webers, more than likely.
velocewest
Columbia Gorge, US
Remember, prior to the m30b35 used in late e24's, e34's and e32's, all M30 heads have identical intake and exhaust passages, valves and combustion chambers, regardless of displacement -- 2.5 to 3.5, all the same.
