bengal taiga
- Messages
- 234
- Reaction score
- 32
I previously posted wondering about alternative sources for rear calipers for a csi. I was having problems dislodging the pistons on one caliper and expected more of the same, but given enough air pressure and pop pop. I found the plating had come off of one of the pistons and just decided to use the pistons from a donor solid rotor-caliper along with new rebuild kits and everything is now operational.
Here is my real question: Many 2 piston Ate rear calipers have pistons with a "C" instead of an "O" surface area that meets the brake pads. Some BMW (like E9's), Porsche and Mercedes manuals state the "C" should be placed at a 20 degree angle using the appropriate measuring tool. Its not difficult and if any of you have read your manuals, you know what I am talking about. What purpose does this really serve? How would being off 10 or more degrees change anything? I mention this since I have rarely seen these calipers (when used) displaying the correct angle on the caliper pistons.
Thanks in advance.
Thanks in advance.
