bmwm3owner
- Messages
- 53
- Reaction score
- 13
Hello,
I have a '72 3.0CS and have some questions regarding the front window regulators and motors - for now.
I have been researching the forum and see that many folks have done the e28 rear window motor conversion. Looks like a nice upgrade. My car has the sardine can style motors. My questions are:
1. Can I upgrade the regulators to the later style? I believe from the '74 up? Will they bolt up and operate the same as the early regulators?
2. I read somewhere that you can use the early Porsche window motors. I ended up getting a couple of new motors for early 911's, up to 1985 I believe. When I received the new motors, it looks like the shoulders where the mounting screws go through the motors are taller than the e28 motors. This make it so that the gear on the motor does not reach the large gear on the regulator. I suppose I could grind the shoulders down a bit so that the gears will mesh but before I destroy some new motors, I wanted to check and see if anyone else has done this before. If I upgrade to the later style regulators, will I have to do this anyway?
I did clean up the sardine can motors and will be greasing up the existing regulators, tracks, etc. to improve performance. Ultimately, I want to do the upgrade, including adding the relays, but before tackling this project, I wanted to check and see if there are available used regulators, just in case my project takes the wrong turn.
