Wire for Oil Pressure Sensor?
Jellobmw
Burlington, VT
About 20 years ago when I restored my 73 3.0cs, I put in an oil pressure gage, and replaced the stock sensor with one that I wired to the gage.
Now I've got a new VDO gage and sensor, and the sensor has an additional lug to wire into the idiot light.
But I can't find the wire to hook up to it!!!!!#$%^(#$%^&*
So, where is that wire routed so I can find it, and is it Brown/Green (as I recall)?
thanks,
Jeff
As a note, the new gage and sensor solved my low oil pressure problem............ I guess it was asking too much of JCWhitney parts to last so long..............
Brown green.
The extra lug is just to wire in series back to the light.
If I understood correctly.:)
i can tell you that the wire that goes to the idiot light is a brown / green wire - it attaches to pin 3 (of the 9 pin connector behind the gauges), and as far as i can tell - its the only thing that attaches to pin 3.
i was testing all of the lights (with my gauges out of the dash) and i mapped where each of the wires feed to / receive from (with the help of the wiring diagram). i wouldn't trust where my sender is compared to your car - since mine has had an engine swap ...
