wiring (4)- h1 headlights on the 74
aearch
Deceased
pleasant hill , ca
as we all know the wiring on these cars vary.
so after a bit of while i have solved the 74.
the low beam relay, the first one under the dash- runs the low beams
and the fog light relay wires to the high beams ,but it wont lite them
so the wiring colors are correct for the low beams.
and the turn signal.
so to run the parking light you need to run a wire from the white low beam connector to the parking light.
on both sides as they are different circuits.
then you need to find the white and blue wire. this is the high beam wire. in the diagram its shown as white
so run that to each side and all lights will work correctly.
i have posted the 74 wiring diagram previously.
also all the light frames should be grounded.
although the lights will work without it.
for the light grounds to the light base.
