I removed the wires from the 3-plug that goes into the old alternator, taped off the 2 not used and plugged the D+ wire back into the new alternator. Then you can keep the old regulator in its spot if you like the stock look, it won't function but it will allow the red idiot light to work. To handle the extra amperage draw from my lights I also ran a separate ground wire from the battery terminal to the alternator case and then onto the block.
