That's ok, I just need the base. My set screw hole in the base is stripped out. Would you mind pm'ing me a pic of the base?Hi. I have the rubber Gasket and the cast metal base and set screw but do not have the two longer bolts to attach mirror to the base.
Thanks for this, I will let you know. Looks very nice.View attachment 146566![]()
Rear view mirror left for all models from 1973 up complete with seal, mounting support and bolts,from remaining stock from original BMW supplier. you need 1 for 1 car
Rear view mirror left for all models from 1973 up complete with seal, mounting support and bolts,from remaining stock from original BMW supplier. you need 1 for 1 carwww.wallothnesch.com
The problem is, someone has already drilled and tapped it (poorly), and there isn't enough space left now to go to the next larger size.IF you're looking to replace it because of a striped set screw, then you might as well just tap a larger diamter thread in there, and get a set screw one size bigger.
If my memory serves me well, the normal set screw is m5, so 5mm diameter. One size bigger would be 6mm, M6.
Thanks, I actually need the chrome base where the mirror stem connects.Here is what I have.
