Does anyone know where I should buy the material to make a set for two Sunroof E9 I am working on?
Thank you
Tony P.
Thank you
Tony P.
Your price is high , plus cost of transportBuy my 74 parts car
This is from the same 74 with sunroof but it doesn’t have the fine checkered marks patterns. I am wondering if this is actually original BMW or aftermarket ?
Thanks Chris ! It makes sense!Aftermarket. There is only one part number in the parts book for a white headliner. Here is my late 73, you can see that the header panel has larger perforations but same pattern.
Chris, the spacing looks the same - it seems just the 2 pieces are turned 90 degrees from one another (which is correct as i remember).Aftermarket. There is only one part number in the parts book for a white headliner. Here is my late 73, you can see that the header panel has larger perforations but same pattern.
