Thank you for that insight – will it only work on the rear windows of the e9? I'm also in need of the platic gear for the front left window, any thoughts?You want the rear window door motor transmission, those are long ago NLA.
Best thing to do is replace the rear window motors to the 1980s E28 5 series rear motors with the integral transmission.
Only rear door E28 motors will work in E9s. You will need 2 rear lefts for the left side & 2 rear rights for the right side. There is a little modification as the screw holes are slightly different & the E28s use 2 wires instead of three.Thank you for that insight – will it only work on the rear windows of the e9? I'm also in need of the platic gear for the front left window, any thoughts?
Thank you – I will investigate. I also heard that you could get the plastic gear fabricated in metal? Or is that a myth!?Only rear door E28 motors will work in E9s. You will need 2 rear lefts for the left side & 2 rear rights for the right side. There is a little modification as the screw holes are slightly different & the E28s use 2 wires instead of three.
e9coupe.com
I have several of these gearboxes in good condition. All the boxes, front or rear, right or left are all the same. I am in South Carolina. Tom Baruch.WTB rear window worm gear clutch
Hi, do you still have one of these available? I just need one for my rear window. It hasn’t worked since I bought it and now I know why…I have several of these gearboxes in good condition. All the boxes, front or rear, right or left are all the same. I am in South Carolina. Tom Baruch. View attachment 136335
