Reference pics. Not particularly easy to make at home.
Don’t underestimate the redneck brake—big vice & 4’ demo bar welded to 3/8” plate.
If you still have the 74 bumpers on your car. When you pull them off, just measure the diameter of the bumper tubes. I don't have handy at the moment or would but that is the exact side you are looking to replicate. I'll try to dig one up though and post a measurement soon.
This is the outside diameter, correct?The measurement is 5 cm precisely.
5cm = 1.9685 inches.
That is 0.8mm away from 2”. Buy some 2” tube (not pipe) and call it good! Tube is measured by OD, pipe by ID.
So, if you want to make some, you might try some 1 1/4" pipe. I'll add the angle of the front-facing brackets on the tube & total dimensions a bit later. I might give it a shot while we're shut in. All that said, I'm still on the fence whether to even use the conversion tubes.
Hi Jay,
Looks like you are good to go. Perhaps it is too tight of a squeeze but 1.75” DOM tube comes out to 44.45mm. Just for future reference if the conversion tubes are NLA.
Dangit, Mark, now I had to research that DOM is. Drawn Over Mandrel tubing definitely seems like a better product for structural pieces and is commonly used in roll bars, etc. The conversion brackets I received have an internal flash weld, so I don't think that's DOM. I found a place in town selling DOM 1.75", 1.51" ID, 11GA, .12" thickness, which would be spot on, but getting a price from them requires some code I don't possess. So, dealing with industrial sellers in the oil & gas pipe yard part of town vs. the 10 min. drive to big box seals the deal for me. At Lowe's 1 1/4" is $35 for 6' and $36 for 10' at Lowe's.
