VILLEocity
I need for a 1972 3.0CSi, what I believe is called the Temperature Retard Switch. The photo shows the switch with the connector end broken off. A working used one would be fine.
Thanks!
Thanks!
Temperature-time switch | 35CEL 12S |
Thank you very much for the info!some folks change the connector and use ljet versions.
Thank you for your response bmwski. Unfortunately, I went ahead and purchased one from WN after sfdon pointed it out (not sure how I missed it in my search). Hopefully I'm all set with injection components now.I have a lot of d-jet stuff, including a complete working d-jet set up,new nos CSI gas tank, and a new pertronix electronic ignition set up with or without a distributor
