WTB used driver bottom door seal in decent condish
Longshot: I am looking for the bottom piece of the driver door rubber seal, the part that fits under the stainless cover plate on the rocker. I know it's all one piece but I am not concerned with the condition of the vertical A-piller section. Anyone? Thanks.
Steve:
Are you asking for the Door Seal item 8?
I believe I saved the seals I removed and you are welcome to them.
Dan
Unfortunately Dan’s piece isn’t going to work after all so I’m still on the hunt!
-Steve,
If the piece you're looking for is the one pictured here, you may have about as much luck as I did last time I was looking for the same discrete part of the entire door rubber seal that is essentially only available as one big, continuous item.
No one had a decent used one available when I last put out a "WTB," - probably because that is the piece that takes the most abuse and gets ripped and torn to such a degree that folks finally buy the whole seal. - and their left overs may be generally okay, except for the bottom part that you need.
You may have better, non-original luck with some of the Steele Rubber alternatives that other members here have identified. They work pretty well. I used the round profile, but would try the non-round profile if was to do it again.
https://www.steelerubber.com/side-bulb-push-on-seal-70-3592-99
https://www.steelerubber.com/thin-side-lip-push-on-seal-70-3801-99
Or maybe someone here just might have some good ones to throw your way. You never know. - Good luck in your search.
Here’s the profile followed by what I am going to try from Steele. Might need some trimming to fit under the stainless. I’ll post results.
Steve - I just did a repair on mine to get me through LOTA, but its not great and its not going to last. Peter Coomaraswamy found a Steel Rubber product:
Mine and my friend's Ceylon have a different profile piece (the one in the pic above) than Peter's. I ordered the other one and see they've already shipped, they could rival BelMetric and McMaster for turnaround. We can compare our hack solutions next month!
Once again, I find myself planning to watch you figure something out so I can just follow in your footsteps.
Am I right, there is a thread on this forum which summarizes all the seal-related stuff?
Maybe - in case this is not there - worth to add the info from above?
Probably this is a question to @Markos or @HB Chris or?
Not so fast, I just realized that the rocker section is supposed to have the plastic ribbing attached to the rubber, I thought it was only held in place by the stainless piece. It's now clear that the ribbing and rubber seal have parted ways over the years, so I am going to splice the new piece in and leave my original ribbing as is. I hope @HB Chris doesn't look too closely!
