Wtb window wiper pivot / hinge (update: part found; 50 euro for whole used but good linkage)
eriknetherlands
Netherlands, Eindhoven area
Rusted out in my car,
One of the pivot points in the window wiper rod system.
The two wipers both rotate inside a shaft. When fully disassembled, the axle in the shaft on the left side of the car was rusted quite badly.
Does someone have a replacement as seen in the pic of the single part?
As these pivots are just in the open environment, i guess most used wiper systems have these symptoms.
So ideally im after a part that is already disassembled and prooven to be (moderatly) ok.
If not then ill have to get something turned on a lathe.
(By the way; it wasn't that difficult to pull it all apart. You need a pulley to pull off the two ribbed cilinders. The white plastic linkages just pull apart by hand. Some more leverage is needed for the black ones, I used a 24 mm wrench to pop them.
