Basically,
I have a friend with a 74CS. It's a very original car but is different than my 72CS. I tried to find this relay on the schematic with out any luck.
The windows won't go down unless you open the door.
Then if you press on or wiggle the most forward black relay next to the battery they will work.
Relay Bosch #13563963.
I have done some Google searching for this number and have not found a replacement.
I also feel there is probably a grounding issue and was hoping someone would point me to the grounding point for the window motors or offer advice on a solution?
Thanks,
Gary
Thanks,
Gary
