should read blinking.......do i need to replace the whole indicator unit in the steering column (expensive), or is there a separate (less expensive)"bit" / fix i can get ? (apols for complete lack of electrical knowledge), regards.....
You might have a short somewhere, or the indicator is connected incorrectly...
.. But at the end of the day, a modern electronic flasher will address the sensitivity of flash rate to load wattage.
One of the threads that discusses electronic flashers can be found at the link below. My own experience is summarized in post #12:
http://www.e9coupe.com/forum/showthread.php?t=12371&highlight=flasher&page=2
The slippery slope of replacing systems with modern ones one by one and when you are done you do not know if you are driving your coupe or a rental car you just got at the airport.
