Fan against radiator 3.0 CSI
neon
Newbury, VT
I made the unfortunate acquaintance of a rock this wkend. The fairing splintered, but more importantly the chin took a hit and was moderately buckled.
On inspection, there was an impact w the tow hook/motor mount strut, though it appears intact and not bent. The chin however moved slightly in, and with it the radiator, and there is a slight contact w the fan when braking. I am concerned about the possibility of motor mount damage, but also looking for recommendations for a body shop which is familiar with the model.
Any thoughts greatly appreciated.
This car was mint just yesterday !
neon
'73 3.0 csi w csl body parts, fiord blue
location, location, location
You mean you don't know neon's location? He's in the rightmost column, below helium in the second row.
I say a CSi means probably European, the careful use of language means British, and by the amount of damage caused by the rock, it must be the Rock of Gibraltar.
We know where the OP is from.....
"The fairing splintered, but more importantly the chin took a hit and was moderately buckled."
Hint- its not Huntington Beach.
hmmm tough crowd. What a way to welcome a newb. We usually do better.
Doesn't sound like he's from around here (Honolulu Hawaii) though.
Friendly banter. To distract him from the car damage ...
"Took it on the chin": Radiator pushed back
Folks
Sorry, location is eastern CT. I guess I am wondering if a competent local body shop is as good as a shop such as VSR1 which is some 4 hours from me.
Could drive the car if I can bring that radiator forward 2 mm.
Neon
Folks
Neon
VSR IS the place to go. Could also go to Sports Car Restoration in Plainville CT, they specialize in 2002s, and have a few E9s there too.
Hope the fan doesn't catch a radiator lip, it sucks. Our fan clutch failed and the fan wobbled and caught the radiator while doing 75.
Thanks Andrew
If I can manage to push the chin forward that little bit and thus the radiator, off to NH I go.... Then again, if I cant, maybe a transport co and to NH anyway. In you opinion, is VSR1 as much expert in body work as in gen mech work? I know they are revered and great people, I have discussed w them.
Dana
Thanks Andrew
Dana
Yes. They are the place to go for everything coupe related on the East Coast. From complex rust repair to 5-speed swaps to oil changes, they do it all.
As a bandaid you could remove the rubber radiator mounts and wedge the radiator against the front clip with some cardboard or something between the back of the radiator and the back of the brackets nearest the engine, this would give you a 1/4" or so to get you there.
Thanks Andrew
Dana
Folks
Neon
Remove the rubbers inside the upper radiator mountings and replace it with something that just press the radiator forward and you'll have at least 5mm for the road trip to the shop.
Do the same with the lower mountings if it's not enough.
Good luck!
/Stefan
Thanks Andrew
Dana
Yes they are expert in bodywork too.
http://www.vsr1.com/index.php?page=race-car-stories-2
my car after a restoration there
In addition to the other good suggestions, you might consider examining the transmission mount. A wimpy rubber mount can often permit the engine to cant - just enough for the fan and radiator to kiss. Carefully raising and/or lowering the transmission while watching the fan and radiator clearance may demonstrate this. Shimming the cross member may purchase some peace of mind, even if it is measured in millimeters.
Without advocating them, there are always other alternatives such as deleting the mechanically driven fan in favor of something electric or even shortening the plastic fan blades.
repair places
Ive heard good and a little bad about SCR from a friend who has a major restoration in that shop.
Automotive Restoration Inc is another good CT place that has done a lot of BMWs
Once you have removed the 4 rubber radiator rubber blocks you can use zip ties threaded through the radiator and tied off to the condenser brackets to secure it for the trip.
