garage sale of e9 parts
not excellent parts, but if someone wants to work a bit, or Split them to build a better part using the bits it is doable and they are perfect for the purpose
parts as they are
all prices in USD + Shipping (for small and light ítems = 18 USD)
PAYPAL accepted
if you need more tan one ítem, a better round Price can be negotiated
RH + LH rear taillight inserts, 80 USD each one, 150 USD both
lightholders for front lights high beam + low beam, 40 USD both
adapter for newer fan visco clutch, only the part shown, i think it is NLA, not sure, 20 USD
rest are sold:
switch to disconnect the battery, 20 USD SOLD
two oil pumps, one old model, another newer model, 40 USD both SOLD
LH side indicator light frame, 15 USD SOLD
RH side indicator light assembly, 30 USD SOLD
LH+RH lateral grilles, 35 USD both. SOLD
front grille, 30 USD, SOLD
RH rear taillight, 100 USD SOLD
DQ, May I ask a question concerning the newer fan visco clutch adapter? I have this on my E3 and the front bolt and fitting are tightened down into the adapter but the fan itself is a bit loose. I was under the impression this thing is tapered like a ball joint and as you tighten the front nut, it snugs the part you show so the fan is tight. I don't think it makes a difference but wonder if mine is just worn down.
last parts
now only available:
last parts available
