Petrolicious article about E9 with M engine. Amazing car...
Looking at this pretty subject begets a trivia question of which I have no immediate answer. The Petrolicious subject sports a 140 mph speedometer, yet all of the E9s of which I am familiar have either 240kph or 150mph gauges. Note that Road&Track also lists the standard US CS model, (the same as the Petrolicious version) as being equipped with the 150 mph version. Realoem ambiguously lists three separate gauges, one fits models from '68 through '75 6212180618. Another fits April '71 through '75 62121353958. Yet another fits February '72 through '75 62121353900. It is unclear whether the different numbers relate to gauge facia including metric or standard English demarcations, or different speed markings (140 v 150), or the "W" (matching) ring and pinion ratio.
Not that it matters much but what models were originally equipped with the 140 mph versions?
FWIW, my E3s were equipped with 140 mph gauges.
Petrolicious:
VW Beetle
iu
Nice instrument cluster montage here: http://www.e9coupe.com/forum/showpost.php?p=49784&postcount=15
That 140 MPH speedometer is not original. The odometer seems to be an LCD display, and LCDs were just being potty trained when the E9 was growing its beard.
Interesting. Thanks for the responses. I looked at the gauge, but obviously not close enough, for this erstwhile analog'er. From what I gather, the only requirement except for cosmetics/fitment is a 12 volt source and antenna mounting.
Redline gauge works charges around $500 to convert a mech speedo to GPS w/that lcd odo window.
An option for sure when converting to a 5-speed that doesn't have a speedo drive. Will be way more reliable.
So a cyber attack could take out your speedo? It's very cool but a little disconcerting. Interesting. I guess if something that disastrous happens nobody will care how fast you're driving your coupe.
