Rear shock top mount steel sleeve dimension
Gransin
Vasa, Finland
Hi,
Can anybody give me the dimensions of the steel sleeve that goes into the rear shock top mount rubber? They are NLA and my car didn't have them when I bought it.
Number 10:
Cheers,
I made some of these not so long ago,
I remember that they were 25 mm long
and a tight fit in the rubber bush.
Hope this helps a little.
Dave
I came across this when installing new shocks and springs awhile ago. My car had 2 different sizes of spacers which became apparent when I was tightening the top nut. The difference in the way the rubber bushing looked smashed was my clue. I ended up using the longer one because it looked normally smashed vs really mashed too much if that makes sense. I believe the spacer is to limit how much you can tighten the nut compressing the rubber bushing correctly. Unfortunately I can't remember the exact length of the 2 (I believe one was about 1" which would be a hair more than the 25mm Dave mentioned.) I ended up using an old front sway bar link spacer that I cut down...seemed to be the right inner and outer diameter. I know DeQuincey did a good write up on changing all the bits and had a photo of some new ones...perhaps he kept the old ones and can give a measurement.
