readie
Can I have a steer in this, how easy is it to transplant an E34 535 manual, 1989, M30b35, engone and gearbox into an e9 ??
IIRC the B35 uses later Motronic and is triggered by a cogged wheel on the harmonic balance so any M30 bellhousing should work However, as Wise 9 said you still need the gear box with a mechanical speedo drive.
Thanks bejoe16, I am in the uk, where are you located?
