WTB Pitman Arm and EGR canister for '76 3.0 Si
John H.
Laguna Beach, CA/Burlington, VT
Hello all, working on my wifes Si and find I need a pitman arm and an EGR canister. Any out there you want to part with or a recommendation for a parts supplier for these? Thanks....
I have the pitman arm for a CSI. I presume that it is the same but there were some changes with the 74+ E3's. Check with @Bavman also. I'm guessing that he has both.
Well I am game, IF I can get it off the steering box. :D A little heat and a two jaw pulled should hopefully do it. I don’t have a dedicated pitman arm puller.
According to realoem, fits an e24 as well. Plug the part number above into the realoem search box and you will see the cross reference. Just the bushing for a pitman arm, e24 at least, is readily available
