Does anyone need a set of complete chrome vent windows? Minor putting but they look quite nice from as close as 2’ away. Desireable green tint. Glass is in great shape.
I'm after the wing/fender ones Markos, but would take the set. How much and will you send to the UK?
Not my circus, but I almost feel like @mr bump is asking about plastic fender and hood grills, where as you are selling vent/fly windows? Or did I get this totally wrong?![]()
On the bottom should be two-sided bolt, so the distance between rail & door frame could be adjusted. By the adjusting on the bottom you will adjust the top.The whole assembly on my car was replaced some time ago, and this bottom fixing is a bolt that goes throught the door metal and into the rail. It's clearly not correct as it can only tighten the rail towards the door, rather than pushing it out, which is what i need to close the gap at the top
Many thanks
Thank you Markos - that's most helpful.
I can't imagine it's going to be easy to track one of these down. Might you be able to let me have some measurements if it is to hand ?
You're too kind Markos
If you could let me know the length of the stud, and at what point the washer is placed, I should be able to knock one up myself
Will do!
