Rear window motor upgrade too?
m5bb
Peachtree Corners, GA
All kinds of write-ups about upgrading the front window motors with the E28 motors. Done!
My RR window does just not want to work.
I've had it apart about 3 times now checking everything.
I've tried a total of 3 motors and 2 gearboxes, all of which have been cleaned and re-greased where necessary.
I can move it with my hand when the gear box is removed but when motor and gearbox are in place it runs about .5 mph.
I thought it was binding some about mid way and have worked on that but it doesn't bind at all at each end.
Driving me crazy.
Is there a motor upgrade for the rear windows?
E28 motor? Has someone tried this?
Help would be appreciated.
Gary
sorry Gary , a bit of topic …. but are the rear units ( motor/gearbox) the same as in the front ? i asked it once over here but there was no reply.... as you have tried several units... maybe you know ?
and now i suspect "not" as otherwise we can do the same conversion to E28 motors... i suppose ?
Yes, the motors and gearbox are the same and since I had two extra motors and gearboxes from the front window upgrade I basically had 4 sets to try.
Something is bent or out of alignment but certainly not easy to correct.
Yes, E28 rear motors work for both front and rear on an E9.
Rear E28 motors work in the front and rear of the E9.
So to replace all, one needs 4 rear E28 motors. Rear motors are around $130/pair from what I've seen on ebay.
Gary,
Confirming above, I replaced both front and rear e9 window motors on my '74 with rear door motors from an e28 a couple of years ago - reduced both up and down time by about 70%. Truly plug and play for the later model cars.
Takes two motors from both Rt rear and Left rear e28 doors to do all four. Only one motor from each rear door to do just the rears or just the fronts, of course.
Gary-
Just got my rears sorted out today using E28 regs, a little bit of cutting but a pretty simple install. I've got a 1970 and it's looking like a wiring change. E28 motors have two wires, while the sardine cans have three, reviewed the diagram and I believe adding a ground wire to each switch fixes it, not tested yet.
So Thomas, did you take out the springs? I saw that mentioned on the forum before but have not done that. Actually if I did that maybe the window would work. May try that tomorrow.
Careful with that eBay listing. In comments it says (fronts). All 4 have 10 tooth gears which don't work with e9.
Previous threads suggest (rear) E28 regs ONLY for all e9 windows. Hope this makes sense
The seller is Ivo Christov who is well known in the E28 community. Easy enough to contact him to get the correct rear E28 motors.
https://www.e28.nl/en/
I did not intend to insult anyone, sorry if that was the case. Just a heads up for buyers that could have bought them expecting it to work on thier rides. The rear E28 regs are the best option imho.
No offense taken nor did you insult anyone. My post was meant to add to yours in regards to sourcing the motors.
I have been supplying these motors for the past year or so. If anyone needs them please contact me.
