Front Caliper Pistons
bavbob
Boston, Ma
Below is a image of a front piston from an E3 on the left and my E9 on the right. The E3 piston came from a caliper I bought used and am using for parts but my 72 E3 had a piston identical to that of the E9 on the left. The E9 piston also weighs a bit more. Explanation?
BTW: What any New England Car guy does before the Super Bowl!...no, not driven in snow, just forgot to cover in storage.
Anti-squeal improvement? I replaced the calipers in my '74 back in 2000 with rebuilds, worked fine for 18 years until they seized again. Noticed then none of the pistons matched, but they stopped the car just fine regardless. If you send out your calipers to be rebuilt by PMB Performance, they will match up the pistons.
PMB Performance: I need mine rebuilt. Do you have contact information and an idea of the cost?
Thanks in advance. Robert Patton
Thanks Chris. As suggested, Sandy, Utah, mail order, I can make that work.
Any idea on the cost? I have the seal kits, but the Pistons are frozen in place and the air pressure trick isn't, working.
Next idea is to use a large tap on the female part of the piston, twist and turn the Pistons out....or just pay the PMB price.
Again, any ideas on cost?
Thanks, RP
i used a hydraulic hand pump ( from a cilinder set ) to push out the pistons.....when air pressure wasn't enough.
To avoid the piston ceasing again. Buy a new set of pads and take 50% of the stopping material off, that way the piston get a better workout and won't cease. The discs are too thick for the calipers and the piston don't pertrude far enough, plus a set of pads will lat us enthusiasts a lifetime the amount of miles we do.
I've done the above and my calipers don't cease anymore.
Sounds like a great way to get lung cancer. Seriously though, how do you remove 50%? CNC?
Probably should be flushing (bleeding) the brakes every year with as little as some of the guys on here drive their cars.
The mere fact that you have to ask how to do this means my reply on how to do it will be lost on you markos. We've done this in motorsport for many years for better effective breaking. Il let you work out how to machine a flat surface.
You are right. I won’t understand. I’m not very technical and have little curiosity about engineering and fabrication. Good luck with your e9 sale. I sincerely hope that it goes quickly.
Your too kind markos, no realy........when it goes i can then start the csl resto, which I'm looking forward to.
