For Sale: 2 red 9-blade fans
I have 2 nice red 9-blade fans for sale. If you want the period look for your upgrade these are it. Difficult to find not all busted up etc. These have no nicks or cracks but could use a little polishing on the visible side of the blades if it matters. The one on the right is a little cleaner, asking $90 shipped USA and the one on the right asking $70 shipped USA. Paypal. Thanks.
HuIwy2ve4zIKZU5jg6oJVtloVFDek0fFq55LcoUZte0aOggR00eEPu59Qmpft6VBVAQIBcewaRGN3ttMz7nTR__hEilUX_5zYGgHILA3Fq3eFN7V2WYkybLj46ZEFO4_o2Z8-lA05L8zRw2fOG_3_SA695y9OS4XFf6yqz8N3P6dbGBn9RV7f56euiDUcESb6fNV4pXK278f08sfQ-1rG3gTduDWDzAcL4QGqgIUQLEykNEuS9-mUpvnUWl4enI4rBmFx9W-OMRTOYTdepsVJ723YJ1_1HP5rmbO9PCulWvmusKxMy6f5xcMVeYEWNQyEI8hTmqFcXkfzOVwYX3jIQ0VeF10DnjeB8Z7hKi50qAsMoKyitbGSRTf7jxbqAIsEyHQ2fgi9gucywgcuWLccTtbUQ1D7kJxSgzh8QcIkgTqOEdx7DF51wNTXaNwxCycJh_l6dDRG6digCM7lp6tC51Pzwb-I1LrqlL70RqCMEwuf7M750CQFlevAy3sugYtJZE4QICt9pZ59AjkR0PoAilkg5r8e07iyjtWVlU9ZvABQymDlD17VGr1RrYvawE6SYvSvySsSQJkj_Qrgb-olabN7YYyrie-bfjTuO9h04cT14kuRnbTC2ktvV353xOKdyohKioAKQELNaX_UGqLzJBf_MxKV8Q=w1036-h777-no
Right one close up:
ZSp5eM9-MZg_QbtVPxLcroXdAbyt9AvtPuzP7ElJSnlzhTWrgpZKrbAknqSJoDq0sRJCYPUQGOUwTrzfe_2zEJFhTOBiT4lPgWfj-c8lewVvHycrYPGdVSqMdE7Rth1rbCGAxh184WGAvF6600AJs_hO_17oV6vS1eGms4ncrbNCB0JdhKDld2xXs2TUIABWGdXdw8G4Xo_zQ2wJ9lyFgrzKPwPTfdEntuu0yYaCne8xGv2HHnnw98irDgMWwnsWSLUaczg1937t-pfNq9lckp4XL_rZvN46BKbci6g_DTlyPoazVhIM0hFrICjB232r4TicuqXiBnoWA0LIHwvI_3u3M78rnLf377cOwC_zn6JOutzzqd1t-lkPlaAuzfhHilLr_TJnijsde0IZG63fQKMx5kgswFv59nn81bel4blRYP9xJztu_rAzWQjOx6msIQDIXqypnjVCjuRhByl_y-8Knw3B-4DpT7aJwXnox03q06PYfQXLrhsXT-KtuzKUFUwd7Uw4wYcoRZ3bbBFqP4lpOIIjeMQEWPoI_Lb96FdXWOX42dMLC5gnyycUs_xsq-dlzbjfh_7jh514as7DAb0DRdHrBNqcdhxeCTglNXojswXA5ibX5hqbtH9gmoA-cSTeL54Q2CqeAxTjgVh4iKO54JtKnB8=w583-h777-no
Left one close up:
lB1XBlWqy5jSbQUxGKXtUFqj7S-Bx1ktlCxy1tlWjco-oApycakQ1r_IXwVKn6Z-JMSwYOaVLdGYPdzOntSMSo9MDJRWpQj8Y9Ako1d99dV1NE6MSa4rdlA3_v4YpbDkhKW_qPdZVcHkEmp1sPgR_c-0rBY3rO4WxYi11ooCK2TT85n5dB68Ta6zBzC4msqDvogiBKJvYzY3MCsZb00UaCYNCnpR9Z5JK8aqJJyW1UtrK3e2PJCxTLcdEaacL_hgmgR4-nE19PvLZ_WMrFbvWWwVRtrisS4QnzH06hGJQebTUq9O1r_Nlbmma4cujLGwdtbkfyLU2tHYbaEQj2q2UudoeaqYa_kXUX5yQOCzDGQT2ipXo3BXbbSixyGHiXGz_m8PM95is3FnDh97rrJ7AhSWdZI-BFuSXVWJ24dbIS5fzlJDSgUEcZfsD-D7qZVW3ww8sEBvHvPZ725Xk4vYRnDaYB6UGaBLlyepzQR7_XauafEj4LCXWWpSiKsq1WbUuE1ZSPgJYWJTK0gMZ_WxYuOa3fzQQ1epop3S9sOiUM3Idk-H3OyKwY7grvke-p5bESqACwYkLyKFR35Xo7aGfp9OuwdSCWOyvDQgtP7rF9of_NqaX_SZvR929h0XzrJ6ohxD7WLP93oMmzhQYJwfT_nJcDjRYaY=w583-h777-no
What a red fan does to the engine look:
a9ey6D0bzakjI4jyKwuKzjOMc34Nv2oh1-ZupA3tLFSdr4D6GZ8TbmCpV2IXPzL8vaD0W2cRPddlvvzfunPQluvvs8zvHsjxxkfcqzePXsXLNdSrODMLl6NjS9r0FIOGCECLycKbTd3MSNNMiHQ2EFLanucj9SXqVfQqJjzhOeKPsknw2PBDB1Wuu7C88E6uTOWid9MCpdS39-Zd91VyZhPP2HFVuBbEmsCpS-Ta8Ewwa9M5wKBM6ViyXgRzPsoqcZvavieK2LV0llDEgnrcs2qz94308ac6YbQp2AW9sKuN51LnNT2xJRMggU04W0zUYkE8x3qM9WuPO-FTrZjbFJ_rsEZIzEq3QkhiqpbbeSF6izP-B9VfjcICVBOgvQYJyfle43rkUwHmyp6vt_EiWeDnQezvWsBH_Q2I1tWY-6BPznxG5ZMt5ANl5V_r8SVfnVHuPjrwb8cWCVRRF6WWjpFZ3MoT81iL45WVOef5abvCh1mQSSDLRv4IwPRoFQgvpjwrqz9VxL9873XJ6h1g3-WKVhy76Dsa610C2T-eqY8-gUxA1FOpU-XHuASVHNFcT8ubAJMu_BnxcVsiBbAKXL3pxwl-3CQa0uVCyMwjFjLXDASMHZSS6qJ11JZd1Kl3s7Ij4KDqENRPStgSJkvVjdXeAjhUHic=w1036-h777-no
Yes it does, I pulled my hair out for 6 months trying to figure out why #1 barrel would flood as revs increased - turns out it was the asymmetrical 5 blade fan, discovered after blocking the airflow to it with a piece of cardboard after umpteen vibration reduction attempts. Solved with the 9 blade fan.
@Stevehose ,
Didn’t you mention that the 9 blade fan helps to keep airflow to the triple setup less choppy?
Thanks! GLWS!
So funny, I had one for my engine and painted it red to match my block and ignition wires. Should have painted the black one and sold the red one. Always do it later. Just think the value will go up and it will be like a savings account. ;)
For the water pump with bolt on fan clutch, spin on fan clutch won’t work I believe and you have to use black fan for those.
Someone asked me recently as they had a red fan and it wouldn’t fit the latest spin-on pump. I could be wrong.
Chris--I have the 9 blades black fan. How do I tell if it is the spin-on or bolt -on variety? I like the look of the red fan.
A large single bolt on front of water pump, 32mm I think. I am checking with Terry Conners, he may have told me about possible mismatch.
Answer from Terry:...9 blade red fan will not bolt up to a spin on fan clutch..... only the fan clutch center bolt style with aluminum stand off will work
You can see on Steve's photo's that there are two sets of mounting holes (one larger & one narrower (for most E9)), so as for me it will work with later M30 clutches with bolt on the clutch.
It will not work with that one (i have):
Your pic with red fan is the earlier bolt on clutch with center mounting post which works. Are you agreeing that the newer ‘spin on’ clutch won’t work? It might also be a clearance issue with the radiator.
no sorry Chris, if one is in desperate need of some money and want to sell us something , it is better we know what is right or not for the intended application …
:p:D:D:D:D:D:D:D
