GLOVE BOX BRACKET
aearch
pleasant hill , ca
CAN SOMEONE TELL ME THE DIMENSIONS OF THE RIGHT GLOVE BOX HINGE
I TRIED Tto get one here but no luck so i need to make one yet the
layout is important so it fits right
just need the dimensions i noted.
center offset from front screw and dim below thew bracket
@aearch,
Responding to our PM thread here for the greater good. After re-examining the bracket, I concluded that it needs to come off to measure properly. It isn’t L-shaped. When you put the flat stock in your metal brake or vise, it needs to go in at an angle.
I am going to remove the part and do a trace. I got
the ugly screw out suprisingly, and I am midway through drilling the other screw. I pretty much destroyed my drill bits on the parts car and a summer fabrication project, so I need to pick up another set today. Their ability to drill through still is pretty much gone.
More in the next day or two. Also, the metal is quite thin, maybe 20 or 22 gauge. It served as a spring clip. You can remove the glove box by bending the bracket.
aearch
pleasant hill , ca
YAE MARKOS ITS DESIGNED WITH THE HOLE FORWARD AT THE BASE
I MEAN
"L" AS IT MOUNT STRAIGHT UP THEN COMES DOWN ON AN "L
OR PERPENDICULAR TO THE TOP
THANKS MARKOS
STILL LIKE TO BUY ONE IF SOMEONE HAS AND EXTRA
OK
I MEAN
THANKS MARKOS
OK
Actually it isn’t designed like that at all. As mentioned it isn’t an L, and isn’t perpendicular to the top. I still need to pick up some drill bits to finish removing mine. I’ll swing by the hardware store today.
Only crappy pic I have, it’s an L, held by a screw if you mean outer one.
I was trying to articulate that it isn’t as simple as @aearch ’s drawing. It is L shaped, but it is not straight. Now that I have new bits, take a look.
Alan, I will trace the part later and send dimensions. This is from my car. I never drilled the head off due to the funny operating angle, but I was able to pop the head off with a pry bar. I have some other brackets but they won’t work.
Mine uses Phillips screws
Same with mine. That whole area of my dash was leaking which is why I had to drill mine out.
@aearch,
Rather than measuring this, I’ll just send you the template. Perhaps you can draw it up nice and repost. We’ve mailed each other plenty of stuff but shoot me a PM with your address again. Thanks!
This is a trace, so the inner side of the line is dimensional. Also, one of the holes really is a bit flat on mine.
aearch
pleasant hill , ca
YES TO ALL FANTASTIC YES ITS A RACING L BRACKET.
IM AT [email protected]
THATS IT THANK YOU SO MUCH FOR THE HELP
MARKOS THE TOP IS INDEED PERPENDICULAR TO THE PART WHERE THE BAR GOES.
OF COURSE IT IS AND ITS AN L LOOKING AT THE SIDE VIEW ON EDGE
YES ILL DO A CAD FILE AND POST IT
aearch
pleasant hill , ca
you could scan it from the top and side and just give me the top width dimension i can figure out the rest if i have that
send a jpg i can work from
Sure thing. You are correct about it being perpendicular. If my car it looked like it wasn’t but taking it out helped. It’s a funny shape so I am glad that you will have the proper dimensions. Also, the metal is 1mm thick.
