Tried to find some info but not about the fan.
My original fan is working but from the sound of it not for much longer.
Thanks,
Gary
Thanks,
Gary
Much to complicated for this "Senior" brain but sounds great.I use the BMW 64541392913 2-speed auxiliary pusher fan from an E32/34/36 powered by a Volvo 2-speed fan relay controlled by a BMW 61311378073 91°/99° dual section temperature switch. Works just fine.
It's really simple. The BMW switch has 3 wires, one for each switch and a ground. The fan has 3 wires, one for each speed and a ground. The Volvo Relay has 3 plugs, one for the 12v power, one for the two switch inputs, and one for the two outputs. The switch in the ground leg of the temp switch turns the fan off. I use a Normally Open relay contact on the ignition circuit so the fan shuts off when I turn the key off.Much to complicated for this "Senior" brain but sounds great.
Good info Mike.My temperature switch is in the thermostat housing.
Good info Mike.
Did you have to drill and tap an additional mount for the temp switch?
I just found this thread, which has helpful info:
https://therangerstation.com/tech_library/volvo_electric_fan.shtml
I'm jealous! I did a complete resto on an MBZ W108 in CA about 20 years ago. Not only was the Pick 'n Pull invaluable for parts, I could go out with my digital camera and take assemblies like the sunroof apart to figure out how to get mine back together years after disassembly! Wish we had them in Europe!I can pick them up at Pick and Pull for $6,
So something like an E28 would have additional ports?
I caught that weak relay design on the Volvo thread, would do it like yours.
When I bought the car it had a fan in it that stopped when I shut off the engine, as is the case with the majority of cars on this page. It bothered me that the fan was running but the coolant wasn't circulating past the temperature switch and it may take a while to get it to shut off. I have two batteries in the car, so I've never had a problem running out of battery. As far as shutting off the fan, the easiest and low current way to do this is to open up the ground to the control switches.
I've never had any temperature problems with the engines I've used, so post operation cooling isn't something that I think much about. The best way to cool the engine is to let it run and circulate the coolant, but my experience is that the harder I drive the car, the cooler it runs.
Looking at Realoem - the 11531710959 housing is the one. Shows up in all kinds of M30 powered models. You want to make sure that the thermostat is compatible with the housing, as there are different lengths.
