5 speed crossmember
bluecoupe30!
I have searched and see some discussion about the crossmember needed when a 5 speed is installed into an E9. The part number in Carl Nelson's article seems to be unavailable now? and I see reference to a cast one being prone to breakage. I was wondering if anyone here has used/adapted one from an early E23. As you can see, it is flat and may not be even close, but perhaps someone here has "experimented" and found a way to make this one work. Any ideas? Thanks Mike
bluecoupe30!
wilies13
Germany, Stuttgart area
Sorry. I do not have this info.
I paid 100€ for the alu part + 2*40€ for 2 used rubbers.
I learned, that the vertical position is important. Just to keep the rubber disc free from torsion.
If you have no other possibilty I can ask the seller. :)
Ohmess
I wanna DRIVE!
Aiken, SC
if SFDon says get the coupeking part ... and then sold all of his stock of the BMW pieces ... that should tell you something. the CK part is amazing. i already have one to onto my coupe
I too have one of the coupeking parts based on Don's recommendation.
To the OP -- I pulled one of the aluminum parts pictured in post 4 and have it laying around here somewhere. If you want it, pm me.
