Wanted: stock carbs or trip webers to rebuild
bossrobot
Berkeley ca.
I have a couple of kits to rebuild the stock Solex Carbs. So, I want to try my hand at going through the stock carbs.
I am also open to try rebuilding triple Webers, but have not found any.
Let me know if you have rebuildable Solex or triple webers carbs.
shanon
NorCal
sidedrafts are much easier to rebuild than downdrafts...but you have one more to do ;)
Ohmess
I wanna DRIVE!
Aiken, SC
I have 2 x 32/36 downdrafts now and I am not that happy with them. I would very much prefer side draft triples
Those are the carbs I pulled from my car when I went to side draft triples. Needless to say, I recommend the change.
mulberryworks
Mr. Fixity
Jacksonville FL
I have .Walker kits. I will reach out to that member
I had read somewhere that the float valves in non OEM rebuild kits generally aren't as good as reusing your stock float valves. I cleaned mine with an ultrasonic cleaner and reinstalled them with new gaskets. So far, so good. Your mileage may vary.
