Radiator drain plug
BarnE9
Barnet, UK
Doing a radiator flush yesterday I managed to lose the drain plug:rolleyes: Quick call to Jaymic the part is NLA so while I track one down (or spend a weekend searching garage for the missing one) anyone know what thread / pitch bolt I could use pro tem? I think it might be M8. Have 73 CSA if that makes a difference
Cheers
Simon
dj_efk
South-West UK
Simon,
I tried to look the part up on realoem for you but couldn't find it - In fact it seems to suggest that your car shouldn't have a drain plug!
I am assuming a build date of June 73 so maybe that could have something to do with it - Or else the rad is not the original one for your car?
Sorry I can't be more help!
Dave.
BarnE9
Barnet, UK
Simon,
Dave.
Thanks Dave not impossible it's not the original rad but my autobooks manual shows exactly what I have (or rather had!)
No worries I'll figure sthg out. Cheers simon
Ohmess
I wanna DRIVE!
Aiken, SC
Simon - I installed a Fumoto drain valve in my car. I have an aftermarket radiator, which had a stopcock valve that directed antifreeze onto my a/c compressor and then all over the garage floor. The Fumoto valve turns the drainage 90 degrees from the radiator, and also allows you to attach a hose and control where the anti-freeze goes when you change your fluid. Obviously, because this fits an aftermarket radiator, you will need to check to see if a M14 x 1.5 will fit into your stock radiator, but you should be able to test this with an M14 x 1.5 bolt.
BarnE9
Barnet, UK
I'll look into that - looks a neat upgrade - but pretty sure it's M8. Thanks
Ohmess
I wanna DRIVE!
Aiken, SC
Yeah, those valves are expensive, but I like supporting companies that come up with really well engineered things like this, particularly since I do my own work.
Bmachine
Northern California coast
@Ohmess Chris did you also install a fumoto valve on the block coolant drain hole? I tried to do that but you need to use their extension because there is a “rib” on the block that keeps you from screwing the valve in.
Luckily they have an extension just for that reason
bavbob
Boston, Ma
I have a cheap metric tap and die set which has bailed me out many times. I also use it to size a missing bolt/nut etc. Takes the guessing out of the equation.
Ohmess
I wanna DRIVE!
Aiken, SC
Hi Bo - No, I just did the radiator. But now that you mention it...
