E3 Wheel color
Dick Steinkamp
Bellingham, WA
My idea of the perfect wheel treatment for an E3 is the low end steel wheels with hub caps and trim rings. Somehow that is THE classic look for these cars (to me). Although my Bavaria came with some fancy aluminum wheels, I NEEDED to change. I was able to find some pretty nice hub caps and trim rings early on in the project. Sooner provided the wheels. When I refurbished them, I painted them black. All steel wheels are black aren't they o_O.
Well, they aren't. One of them many things I'm learning doing this project. The steel wheels on E3s (and on the 2002s) are argent/silver. I repainted them this week. The wheels (and car) do look much better to me with the wheel color change.
Before...
After...
dang
Administrator
Rocklin, CA
I've always used Krylon Dull Aluminum for my steel wheels. Couldn't find it at the store and had to order it last time.
Yep Krylon Dull Aluminum was the go to back in the day. Also had to order mine but glad thry still make it
kkro
Oslo, Norway
Before...
After...
That made a fantastic difference in overall look. Now it looks fabulous!
Dick Steinkamp
Bellingham, WA
I had an original spare to go by that I matched to and I'd agree that the finish was not shiny...not metallic. I used a silver/argent paint with a satin sheen VHT wheel paint. It is probably dull enough to pass muster.
Dick Steinkamp
Bellingham, WA
Thanks. The black is boring. The silver gives the wheel depth and the appearance of a greater wheel diameter (important with these little 14" wheels. ;) )
I think it looks good. I just did my spare 2002 wheel in Wurth Silver, looks great, just needed to knock down the roughness with some 600 grit.
Dick Steinkamp
Bellingham, WA
Try a maroon Scotch Brite. About the same as 600 but easier to get in all the nooks and crannies. You might even try a grey Scotch Brite. Finer than a maroon and it might do the job.
kkro
Oslo, Norway
Hi guys. Could anyone of you please confirm what is the correct factory steel wheel that fits the chrome rings discussed in this thread?
What is the correct width? 5,5inches or 6,0inches?
What is the correct design to actually fit the chrome rings and covers?
Are these the right ones?
Dick Steinkamp
Bellingham, WA
I think all E3 steel wheels are 6" wide (my knowledge of E3s is limited and there may be exceptions)
That looks like the right one to me. Here's one of mine...
ThaddeusW
New Member
Decatur, Ga
The silver on the steelies looks perfect to me. I was planning to paint mine black until I saw this thread.
What is the right paint brand and color for engine parts? Planning silver for the aluminum bits and black for the case. I'd also like to repaint the air intake if I can find the matching color.
ThaddeusW
New Member
Decatur, Ga
Engine block looks best in satin black. I wouldn’t paint intake parts and such with paint as it can absorb the oil and dirt over time.
Thanks. Does the same apply to all aluminum parts? Im thinking of the timing chain covers, water pump, oil pan. If not, what is the right color? The Argent silver mentioned above or more like a flat aluminum?
For aluminum parts I think the best approach is to have them tumbled in media and then clear matte ceramic coated, brand name is Cerakote, very easy to spray with a finish gun.
