nobrakese28
- Messages
- 232
- Reaction score
- 12
35) Install transmission, make sure you have it filled with oil, it will take a little less than two liters. I used Redline MTL GL-4, order a head of time.
35.1) Now is a great time to install guibo, pay attention to arrows along of perimeter of guibo. They should point to the yokes.
35.1a) Grease the splines and bearing shaft.
35.2) With an assistant, lift the trans and install into bell housing.
Wiggle and push from the guibo side. It will eventually go in, if not use the four nuts to bring it in.
35.2) Torque the nuts, remove the clutch master cylinder to access the top left nut. Its a real PITA. I think an S-drive wrench would work. I just got it as tight as I could.
35.3) Replace slave cylinder (with hose) and torque nuts.
