Motronic wiring harnesses use that same wire Steve. Where does the other end attach?I still need this piece, which slides over #1 spark plug wire if anyone has one lying around for cash money
I never knew it works on 6 cyl motor, that is good news. Too bad I used the red power there for my lo beam relay! The Tune box reads voltage, dwell and rpm only as well as starting motor while never turning ignition key so all other accessories remain off. It is a great tool.It does work on the M30s and it also can be connected to an AFR signal.
Here is the latest postings on the Tunebox https://www.bmw2002faq.com/forums/topic/247596-gauging-interest-in-tune-box-run/#comments
