Quick question about rear seat in 2800
americium
Near Chico, CA
I have been pulling out the old seat covers and the blue vinyl under it is near perfect. It was a great surprise. Even the driver seat is great. The carpet is great too. Looks original. The doors also look great, except for the drivers side door pull. It’s broken at the top. Here’s pics.
which brings me to my question. I pulled the rear seat bottom out easy enough but what hold the upper section in? I pulled a bit on it and it seems solid. Are there screws in the trunk? I have all the original elephant skin so can’t see behind unless I remove the center section.
There is (or should be) a screw on each side near the bottom of the back cushion that is exposed when you get the bottom cushion out. Then it lifts up and out.
What Dick said, lower left/right corner phillips head screw, remove those and slide the seat up and off. Do not pull the bottom out too far before you slide it up
for cleaning and restoring the vinyl, get a bristle brush, like a shaving brush or a fat paint brush, 50/50 diluted simple green. swirl/scrub the simple simple green to lift the dirt out. rinse and maybe wash rinse twice.
once it's clean as heck, use mineral oil. the cheapest I've found is at CVS. use something like terry cloth, get it good and wet and massage the oil in, let it soak for a bit (10-30 minutes) and then use a clean towel to wipe off any excess.
ALSO, dont use any silicate based vinyl restorer products. they actually dry out the vinyl and make it crack unless you want to reapply it weekly. Armorall and Son of a Gun are the worst. just use mineral oil.
I had heard that Armorall type stuff could be doing the opposite of preserving, you confirm it. I definitely don’t want to damage these seats after all the years they have survived. Thanks for the advice, I will be starting the process soon.
I wouldn't put Armorall on vinyl seats. You'll slide right off of them :oops:
Ok, here are pictures of the 3 screws holding the upper rear seat in place.
this one is a little difficult to see because of the sagging seat cover
here’s the middle
And here is the opposite side
Pinnacle vinyl and rubber conditioner is awesome. I just clean with Bronner's liquid soap unless soil is heavy and then apply coats of Pinnacle vinyl and rubber conditioner until there are no dry spots anymore. Buff after the vinyl is nourished.
As long as the rubber or vinyl is not completely dry rotted, the product will bring it back. I have used it for years on E30 dashes and the un-cracked dashes are my proof. Initially, the vinyl will soak it up but upon consistent saturation the finish will level out. Buff and the original finish will be restored.
Do you recommend using their cleaner first to get out previous treatments of other brands (Vinylex)?
